Only need: $19.99
Link: http://bit.ly/2Ggfmga
The device measures 80 x 53 x 30,4 mm, and the weight is 83 gram. It is watertight, it guarantees the IPX7 certificate. It looks like a bar of soap. It is available in four colors: pink, gray, orange and green. The battery capacity is 300mAh. Xiaomi declares that it is enough for 3-4 hours of continuous use. Charging is done using the cables included in the kit, and customers will also receive a transparent case for storing and transporting Xiaomi InFace Sonic Clean.
The product is advertised for both women and men. Removes excess makeup, cream, oils, and fat from the skin. It must be said that pure skin is not only conducive to beauty but also healthy, because clean skin breathes more freely. It will be less prone to premature aging, and with the new InFace Sonic Clean the face cleaning operation is very simple and takes 90 seconds.
The small motor that powers the cleaning bristles of this product is produced by Seiko, while a small MCU processor sets the energy that will be dispensed through sonic waves, effectively reducing the pressure that may be on the skin. The material used in the entire casing and the bristle itself is a food grade silicone with a thickness of 4.5 mm and FDA certification.
The use of sonic wave technology, in combination with vibration, allows a precise cleaning to the skin substrate, thus avoiding the enlarged pores. Finally, only 90 seconds will be enough time to obtain results worthy of the best beautician thanks to refreshing the face and, why not, give a good mood to face a long day of work.
The Xiaomi inFace Electric Sonic Facial Cleansing Brush is currently available on coolicool for $19.99 and comes with a free shipping option.
