V88 Problem with android box
Hi people maybe can you help me, with this android box V88, then i power on its showing android login after few 3 sec it's showing other android log and stuck. how i can fix that problem? i was trying go in recovery mode but nothing happen black led power lamp even don't turn on, and black screen i was trying plug with usb 2x male writing unknow device i install drivers like Driver Assistant v4.5, RockChip_Batch_Tool_v1.8, USB Burning Tool v2.0.6.2, and still nothing can't detect dives, was trying even USBDeview removing all usb ports still nothing unknow devices.Tags: None
Originally posted by Edgis View PostHi people maybe can you help me, with this android box V88, then i power on its showing android login after few 3 sec it's showing other android log and stuck. how i can fix that problem? i was trying go in recovery mode but nothing happen black led power lamp even don't turn on, and black screen i was trying plug with usb 2x male writing unknow device i install drivers like Driver Assistant v4.5, RockChip_Batch_Tool_v1.8, USB Burning Tool v2.0.6.2, and still nothing can't detect dives, was trying even USBDeview removing all usb ports still nothing unknow devices.
first no USB Burning , you mean for SDupdate or what ??? , you need Batchtool , better AndroidTool ,
above 2.35 & latest Drivers , do you have the latest StockRom ??? , this is needed to restore ,
later i can uplaod for you if needed ,
greetings / gefattern
Hi ,
i don't have, i just remove now cpu heatsink and its writing AllWinner H3 cpu so i was trying google it i just found something like that H3-R69-MXQ-S-MXQ4K-8PD3-1.1.4(2).img so i don't know or it will work, i am little bit lost sorry for that
if this is sure you must change to Allwinner Section , not sure what Tools are needed ,
sure is , you bought one of the cheap fake PCBs , with other parts , further good luck ,
you only can try to get Stockrom from Seller or try the one you found , cheap Box ,
There are currently 2829 users online. 0 members and 2829 guests.
