Help with firmware to TX9 - Amlogic S905W + wirelles chipset RTL8723BS
    I bought a TX9 TV Box with these configurations:
    - Board: TX3 MINI-A 2+16 (181226) 8723
    - Amlogic S905W
    - Wireless: RTL8723BS E9E2131 DG45D
    - Storage: 16 GB
    - RAM: 2 GB (5NN77 -5 AF 1844)
    - Android 7.1.2
    I did a stupid thing and tryed to change the Android to the Tanix TX3 Max, because it's Android was compatible with the Tanix TX3 Mini and, in theory shoulb be compatible with the TX9.
    Now It has a black screen ant the led shows "boot".
    I tryed to upgrad the firmware using my PC, following this tutorial: https://androidpctv.com/firmware-upd...x-soc-amlogic/
    Every time I get "[0x32030201] Uboot/Get result/DiskInitial error" and stop at 7%. I tryed with several images.
    Did anyone knows a compatible firmware or the original one?
    No one have any ideas?
      I had the same problem, did you find a solution?
        - Amlogic S905W
        - Storage: 16 GB
        - Android 7.1.2
        friend, I have the same problem, solving problems?
          do you can try apply this tutorial maked by me =)
            Eu tenho uma rom que é compatível com a tx3 tx9 com a launcher da Alice Ux
              Pode colocar essa rom que vai da certo vou deixar o link aqui pra vcs baixarem fiz a mesma coisa que vc fez deu merda ai eu achei essa rom link >> http://www.mediafire.com/file/j2mu3o...i-TX9.rar/file
              • gefattern
                gefattern commented
                Editing a comment
                Hi , same for you , translate both Threads to English , thanks / gefattern
              Alguém teria uma rom compatível com a placa v1.2 ( placa vermelha). Obrigado
              • gefattern
                gefattern commented
                Editing a comment
                Hi , same for you , translate it to English , thanks / gefattern
              Qual versão do USB estão usando
              • gefattern
                gefattern commented
                Editing a comment
