Eachlink H6 Mini TV Box Provides 6K Clear View
    Equipped with the single-chip Allwinner H6 system and Mali T720 GPU, the Eachlink H6 Mini TV box offers 6K output and supports HDR 6K images, provides ultra high definition and fluent video playing, becomes the highest resolution signal available for home movies. The box runs Android 7.0 Nougat operating system and gives access to all apps that are available on Google Store. It comes with 3GB RAM and 32GB ROM storage space, enough for installing any of your desired apps so that you won't worry about video interruptions and picture distortion.
    Main Parameters:
    CPU: Allwinner H6 Quad-core A53 64Bit
    GPU: Mali-T720 MP2
    OS: Android 7.0
    RAM: 3GB DDR3
    ROM: 32GB eMMc 5.0
    Max. Extended Capacity: 64GB
    WiFi: IEEE 802.11 b/g/n/ 2.4GHz
    Ethernet: 100M LAN standard RJ45
    6K Decoding: Support
    Bluetooth: 4.1
    Video Decode: H.265/HEVC Main/Main 10 profile@level 5.1 high-tier, VP9
    Video Output: 4K ? 2K & Full HD 1080P@60fps
    10Bit provides 1.06 billion colors and restores a more realistic world color, you will get clear immersive picture quality optimized for your TV with crisp details and rich color, all the details will be caught by your eyes: https://gearvita.com/eachlink-h6-min...-32gb-rom.html
    Recommended products:
    redmi note 7 64gb global
    lenovo watch x waterproof smartwatch
