Beelink GTmini-A TV Box - True 4K, More Natural
    Beelink GTmini-A TV box features Amlogic S905X2 SoC processor and integrates a powerful Mali-G31 MP2 GPU for a strong performance. Built-in HDMI 2.1 transmitter including both controller and PHY with CEC, dynamic HDR and HDCP 2.2, 4K@60fps max resolution output. It is equipped with LAN 1000Mbps and 2.4G + 5.8G dual band WiFi for faster and more stable network. Packs a lot of connectivity ports into a small space, it can easily connect to your HDTV. The TV box also comes with great a voice remote control with air mouse, which makes the operation much easier and faster.
    Main Parameters:
    CPU: Amlogic S905X2, Cortex A53, Quad-core
    GPU: Quad-core ARM G31 MP2
    OS: Android 8.1
    Storage: 4GB DDR4 RAM + 32GB ROM
    Max Extended Capacity: 64GB
    Decoder Format: H.263, H.264, H.265, HD MPEG4
    RJ45 Port Speed: 1000Mbps
    WiFi: 802.11 a/b/g/n/ac, 2.4GHz + 5.8GHz dual band WiFi
    Bluetooth: 4.0
    Interface: AV, DC Power Port, HD, LAN, TF card, USB2.0, USB3.0
    Beelink GTmini-A is made in a laconic design and is small in size, which means it will not take up much space, but has a very powerful image and video processing capabilities: https://gearvita.com/beelink-gtmini-...-32gb-rom.html
    Recommended products:
    xiaomi mi mix 3
    lenovo watch x
    Netflix certificate?
    Enviado do meu ONEPLUS A5000 atrav?s do Tapatalk
    • mo123
      mo123 commented
      Editing a comment
      No, uses same tricks as Mecool devices that were banned.
