{ROM} PoisonATV V4.9 S912 FINAL
    That work for me thank you
      performnce v4.7 patch uploaded already enjoy everyone
        Okay I'm going to give it a try thank you I'll let you know pretty soon when I finish putting back everything together
          I tried the patch performing but still free slack . Went back to Firmware 4.5 with no issue. I would love to get firmware 4.6 but the issue is the sleep mode not working well on my box minix u9h
            Sunvell T95Z PLUS 2/16 Gb
            Well i have flashed this using USB Burning Tool 2.1.6.8 normal erase and it installed with no errors then i let it boot and play store works fine for me rebooted into recovery and flashed the required items
            T95Z clock patch no:-1
            Q9377
            Bluetooth 4.1
            sunvell remote patch
            performace 4.7
            rebooted and all is well connected by ethernet and wifi 5GHz and 2.4GHz
            went to TV Apps and tried the amazon prime but all i get is download error 402
            so i install aptiode and get amazon from there and it WORKS for me
            now going to install all the other bits i use
            Many thanks for this first version that got amazon prime to work for me
            only thing i find difficult is screen resize as a black screen on a black background it difficult to see ....lol
            again many thanks to you and the team for this
              Found some playback issue .... working on new build as we speak to fix issue and make it more stable .... everytime i fix one issue another arises lol but ill get it fixed v4.8 have to come now ... didnt want to but patches alone wont fix i have to update the build
                Well for me same result that firmware 4.7 I put the new firmware 4.8 same issue. I use burning to 2.17 erase all same result of video. And some apps don't want to open. On firmware 4.5 not a issue Arrow on firmware 4.6 the only issue sleep mode on video and quality is good no complain just sleep mode on on firmware 4.6
                  try to reburn im not having any issues over here what box do u have
                    Minix u9h I'm going to flash 4.8 three times in a row..... on the other firmware 4.5 not an issue at all on firmware 4.6 the issue sleep mode that's it
                      I flash my Minix u9h 3 time using burning to 217 erase all my issue is the same when I'm using stb emulator on my IPTV private servers I change the player on the menu to internal player in the freez go way. When I open another APK IPTV service and I change the player to MX Player freezing stop
                        My stb emulator working amazing now ... I use Phoenix streams
                          and some apps I get this error this in responding close or wait
                            Well I went back to the firmware 4.5 not freezing and no error on App. And sleep mode work and. A3 remote control minix u9h work turn on end off
                            with modification remote conf
                              cant install this new rom on h96pro plus! ill get error dont know the reason
                                First I want to thank you for this great rom!
                                I'm new to these android tv boxes.
                                I've bought a beelink gt1 ultimate lpn1 (lpddr3) tv box one month ago and the stock rom was awful.
                                Now I've tried several custom roms and your rom is for me the fastest and the most stable one.
                                I want to report just few things I've recognized:
                                - Navigation bar isn't working
                                - Setting to hide onscreen keyboard with a connected usb keyboard is missing
                                - Can't change keyboard layout to QWERTZ
                                - Setting to change standard apps is missing or I can't find it
                                Additional I have a question regarding video decoding and I hope, that you can help or explain me my problem. The main reason, that I've bought this tv box is the steam link app, to stream my pc games to my tv. I have the problem, that the app only work, if my pc is software encoding with libx264. If I change it to hardware encoding (AMF H264 or AMF HEVC) with my amd rx580, the display latency goes up to over 1000ms and the app crash after some seconds. It's working fine on my sony xperia xz premium smartphone with a snapdragon 835. This issue was at all roms I've tried. More or less I want to know, if this is a hardware problem or just a software/driver problem. If this will never work on this box, then I will probably sell it.
                                I don't expect a fix now to my issues, but maybe you can eventually consider it at V5.
                                Thank you very much and sorry for my averange english skills.
