{ROM} PoisonATV V4.9 S905W
    POISONATV
    Here we go with a new Version of the PoisonATV Firmware.
    We are supporting S905X, S905W, and S912.
    This Thread is about the S905W Version and only this Version will be supported in this Thread.
    CHANGELOG
    V4.9
    -Stability update
    -New Tweaks
    -Final for this firmware
    V4.8
    -Fixed video playback issues with some apps
    -fixed some permissions
    -added some more tweaks for speed and better video quality
    V4.7
    -fixed sleep mode on some boxes
    -added memory cleaner (Launcher icon instead of banner)
    -Changed boot logo
    -Changed bootvideo
    -changed launcher wallpaper
    -Added Tv Voice Input (ported it from another androidtv not sure what it exactly does)
    -erased old memory cleaner
    -erased gallery (not used in androidtv anyways)
    -Added build.prop tweak for netflix (Not sure if it helps but ported it from another androidtv)
    V4.6
    -Based on Vorke/Tanix firmwares
    -Twrp Recovery
    -Init.d Tweaks enabled
    -Modded UI
    -Modded Framework
    -Gamepad/controller support
    -PictureInPicture Feature
    -Voice command enabled
    -Re-designed Look (Black&White)
    -Modded Wifi drivers
    -Optimizer app added
    -Airscreen Added (GoogleCast alternative)
    -Removed Netflix ESN (Broken anyways)
    -Root enabled by Default (Can be controlled in settings)
    -Autoframerate options
    -Removed Moresettings(Broken/Useless)
    -Tvapp Repo Added
    -Tweaked GoogleServices
    -MultiTasking Enabled
    -LockedScreenRemoved
    -Amlogic Codec Added
    -Zipalign On everyboot
    -SnappyUI Mod Added
    -Bugs???
    Stable
    Installation
    -Recommended to use amlogic USB Burningtool 2.1.7 With force erase option enabled (NOT NORMAL ERASE)
    -Sd Burncard tool not recommended as users usually report issues with their systems
    -Playstore takes Time to kick in but works
    -Pick 1GB or Regular Version Depending on your device
    THE PROJECT:
    Poison is a community project that aims at giving users the best Android TV experience possible.
    Currently, we only support AMLogic based devices but we are working on branching to other chipsets.
    So enjoy the cleanliness, optimized and powerful feel of Poison!
    Project developers are Ricky Divjakovski, Whiteak, minixfreak and @neomode.
    DOWNLOADS:
    Builds are uploading right now, Be Patient
    DONATING:
    You can contribute to the project by donating at PayPal.Me/PoisonDevelopers
    If you would like a custom built firmware we are able to do this, email [email protected]
    SCREENSHOTS:
    Wasn't 4.5 the last one? Said wouldn't do more.
      WiFi and bluetooth don't work on a H96 Mini (HS2734A chipset).
      The TWRP has a split screen bug.
        Did it work previous ones pretty sure I do t support that wifi in my firmwares
          Never tried previous versions.
          I have been using the stock firmware, but after testing this rom, I also tested atvXperience v2FF and v2H and they also lack the HS2734A driver. However, in the v2H version the TWRP split screen bug is solved.
          The stock firmware is ok and let me change the launcher without problems (something that isn't true for every device, Mecool for example sucks), but I'm trying to find one firmware with PS3 drivers to give retroarch a go.
            I will try 4.9 update.
            I had 4.5 before and i thought it was the best until 4.7 came out in which i felt like it was buggy. i hope 4.9 fixes everything... any way to install this custom rom without erasing old install? it is not a big deal because re installing the apps is a no big deal.
            let me know if i can install this new update over the 4.7 while maintaining my old apps and data.
              Thank you for putting in work. I appreciate the updates. Will 4.9 be the last?
                Yes this is the last ... I'm starting on other chipsets and have very limited time now
                  This 4.9 edition is causing problems for me. I notice the box freezes from time to time. This happens when I use STB EMU
                    Version 4.9 I am trying to flash using USB BURNING TOOL 2.1.6 and after boot it gives me the new boot screen screen goes black and then box disconnects from tv. does not boot at all.
                    I tried Force erase ll , normal erase and with Erase bootloader check and unchecked. What am I doing wrong? 4.3 I never had any issues installing. My box is x96 mini.
                      Any update? Have you tried to replicate this problem?
                        Hello,
                        I am having issue with getting this to work with a tanix tx3 max, install goes fine using usb burning tool 2.7, no errors, after hooking it back to the tv i see the boot screen and then screen goes black, i have let it sit for about 30 mins still nothing, unplug it and plug it back no boot screen just black screen.
                        Any help would be greatly appreciated.
                        Thank You.
                          Originally posted by wbetts1972 View Post
                          Hello,
                          Thank You.
                          Might be rebased off another version give me some time to fix
                            Thank You.
