MT 4K N1 Android Box Flash files
A mate has one of these boxes that he got from someone who used to work in Singapore, Been working well for him for over a year but since Thursday it seems to be stuck on the boot logo. I have tried to press & hold the reset button while powering it on to get it to the recovery screen but when I do that I only get the screen with the android lying down with an explanation mark in a triangle sticking out of his belly then it reboots itself after a few minutes rather than giving me the recovery options. So looks like it needs reflashed but I cant seem to be able to find any support or flash files anywhere online for it. Can anyone help me with this or if I could install a flash file from another similar box to get it working again?Tags: None
Originally posted by MurdoTM View PostA mate has one of these boxes that he got from someone who used to work in Singapore, Been working well for him for over a year but since Thursday it seems to be stuck on the boot logo. I have tried to press & hold the reset button while powering it on to get it to the recovery screen but when I do that I only get the screen with the android lying down with an explanation mark in a triangle sticking out of his belly then it reboots itself after a few minutes rather than giving me the recovery options. So looks like it needs reflashed but I cant seem to be able to find any support or flash files anywhere online for it. Can anyone help me with this or if I could install a flash file from another similar box to get it working again?
without knowing what CPU is used , no chance to help , best pictures of PCB , both sides ,
then maybe , help is possible , and more Specs infos RAM/ROM/Wifichip/CPU , so
open up is only chance to see the truth ,
greetings / gefattern
Originally posted by MurdoTM View PostPhotos attached including spec sheet I found online.
u must search for a RK3229 / 1/8GB / with right Wifichip support , think it is the 8189 from
blablabla Chipproducer , maybe this :
or
and you can search here for the right Rom in the right Sections or with "search" , but most
important is before you do anything , read & ask in the Thread of the Rom you want to try .
It is a cheap Box , rebuild by so many Brands , with different Specs , remember always ask
if something is unclear ,
good luck / gefattern
Originally posted by MurdoTM View PostThanks for that. I found a compatible firmware from the MXQ box, Android version 6, which it says is the latest version for this box, not sure what it was on before as i never seen it working. Up and running again.Much appreciated.
nice to hear , good luck further / gefattern
There are currently 1931 users online. 0 members and 1931 guests.
