EACHLINK H6 Max TV Box - Android 9.0, 6K UHD, 2.4G + 5.8G WiFi
    The EACHLINK H6 Max TV box is equipped with Allwinner H6 SoC processor, capable of processing video up to 4K resolutions at 60fps and 6K at 30fps thanks to the Allwinner Phoenix 3.0 VE engine. It has 4GB of DDR3 RAM and 64GB of eMMC storage memory that can be expanded via the microSD card reader found on one side of the box.
    Main Parameters:
    CPU: Allwinner H6, Quad Core, Cortex A53
    GPU: Mali-T720MP2
    OS: Android 9.0
    Storage: 4GB RAM + 64GB ROM
    Extended Capacity: micro SD up to 64GB
    Decoder Format: H.264, H.265
    WiFi: 802.11 a/b/g/n, 2.4GHz + 5.8GHz dual band
    RJ45 Port Speed: 100Mbps
    Bluetooth: 4.1
    Interface: AV, DC power port, HDMI 2.0a, LAN, SPDIF, TF card, USB2.0, USB3.0
    Language: Multi-language
    The EACHLINK H6 Max offers 6K output which provides you ultra high definition viewing and fluent video playing, making it as the highest resolution signal available for home movies. Coupon code "GV6OFF" is used in this TV box for a 10% discount: https://gearvita.com/eachlink-h6-max...-64gb-rom.html
    Recommended products:
    xiaomi redmi
    lenovo k5
