Beelink BT3-X mini PC - Upgraded Performance for Double Work Efficiency
    Beelink BT3-X mini PC is a low consumption device with small size, easy to carry and save desktop space. As always equipped with Windows 10 as operating system, based on the Intel Apollo Lake J3355 processor, which stands out for the easy-to-expand external storage thanks to SATA3 and M.2 ports.
    Main Parameters:
    CPU: Intel Apollo Lake Celeron J3355 (2M Cache, 2.0GHz up to 2.5GHz)
    Graphics: Intel HD Graphics 500 (4K 30Hz)
    OS: Windows 10
    Storage: LPDDR4 4G RAM + eMMC 64G ROM
    Extended Capacity: Up to 2TB
    WiFi: 802.11 b/g/n/ac, 2.4/5.8GHz dual band
    Ethernet: 1000M LAN RJ45
    Bluetooth: 4.0
    Interface: 1 ? DC Jack, 4 ? USB3.0, 1 ? RJ45, 2 ? HDMI, 1 ? Audio Jack, 1 ? TF Card Slot
    Internal Connector: 1 ? MSATA SSD, 1 ? MINI PCIE, 1 ? SATA HDD
    Beelink BT3-X comes with an excellent cooling fan that is excellent for longer-time running, good heat dispassion and air vent design can effectively ensure the high-performance operation and extend the service life. The mini PC is now on flash sale: https://gearvita.com/beelink-bt3-x-w...-64gb-rom.html
    You may also like:
    xiaomi mi mix 2s
    xiaomi mi 9
