Beelink GTmini-A Amlogic S905X2 Android 9.0 4K TV Box with Voice Remote
    Beelink GTmini-A Amlogic S905X2 Android 8.1 4K TV Box with Voice Remote Dual Band WiFi Gigabit LAN Bluetooth USB3.0
    4GB+64GB / 4GB+32GB For your reference.
    Amlogic S905X2
    This Amlogic S905X2 processor fully supports premium 4K UHD video. This powerful 64bit CPU and G31 MP2 Graphics GPU combination handle 4K graphics better than most products on the market.
    Android 8.1
    It is based on the latest Android 8.1 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
    2.4G/5G Dual Band WiFi
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    True 4K Media Player
    While your average media box might only accept 1080P video playback, this gadget plays 4K video from almost any source you can think of. Furthermore, it uses VP9 hardware decoding alongside the H.265 to bring fantasy into reality.
    BUY NOW.
    $79.99 after coupon: DUAXYNKJ for 4GB+64GB
    $75.99 after coupon: IOXFMJNT for 4GB+32GB
      Is Netflix 4K for sure in this thing?
        It supports
        Netflix.
          It's running Android 8.1, not 9.0.
            Oh yes. Thank you for your info.We will fix it.
