(ROM) GoogleTV V1.0 S905W
    GoogleTV_V1 Changelog
    -Based off Poisonatv v4.9
    -Fixed Memory leak
    -Fined tuned System
    -New UI
    -New Tweaks
    -Stable&Fast
    Enjoy Everyone
    Download:
    Builds are updating Be Patient
    -Fixed Memory leak
    -Fined tuned System
    -New UI
    -New Tweaks
    -Stable&Fast
    Enjoy Everyone
    Download:
    Is this better than Poison 4.9 because that won't work for me as I previously stated. Just boots up with logo and turns off. Box is x96 mini 2GB
    Edit: Just flashed it, same problem as 4.9 it won't boot. This not even the logo pops up
      Not sure if this is normal but it hangs there for awhile before giving the green complete. Also those are the options I used let me know if Im doing anything wrong.
        u have to have erase bootloader as well
          Tried that as well. I'm getting the same problem. 4.3 worked for me but some how newer ones didn't.
          Did you change anything? Booting problem only on new ones after the new boot logo. I have x96 mini 2GB
            Hello,
            I am having issue with getting this to work with a tanix tx3 max, install goes fine using usb burning tool 2.7, no errors, after hooking it back to the tv i see the boot screen and then screen goes black, i have let it sit for about 30 mins still nothing, unplug it and plug it back no boot screen just black screen.
            Any help would be greatly appreciated.
            Thank You.
              Originally posted by wbetts1972 View Post
              Hello,
              Thank You.
              Don't use s905w use s905w 1gb
                Unfortunately that did not work.
                  We rebase firmware hang in there everyone
                    Thank you. Looking forward for a working release.
