H96 Pro+ for French Users
    H96 Pro + for french
    04-30-2019, 02:36
    Hello, I open this self-help post between french for users of H96 Pro +
    Personally I have a box H96 Pro + 3G SSB 32G SS blue PCB
    I like a lot of french long looking for a way to be able to watch my channels on the mycanal app on my box with the remote control (short without having to plug an additional mouse) in vain. Having found a solution, I share the info.
    Rom having MYCANAL in still image:
    - ATV superceleron roms (see this forum)
    (if you have any other thank you for telling me to expand this list)
    roms or MYCANAL works WITH the remote control (including scrolling channels ):
    - aml_7.1_s912_q201_9377_H96PROPLUS_KDMC_LP_mac_2018 0824 (link below from another discussion of this forum)
    https://drive.google.com/file/d/1mCz...tHzmxShHi/view
    Useful multimedia applications and tested:
    From the GooglePlay official:
    • Mycanal v3.6.6
    • Molotov TV v3.4.3 (the status bar at the top remains visible)
    • Is v18.2
    APK issues downloaded from a discussions dealabs here is the link: https://www.dealabs.com/discussions/applications-apk-some-applications-apk-for-android-tv-atv-of-tv-francaises- 1090244
    Hello thank you
    Bonjour merci
    • gefattern
      gefattern commented
      Editing a comment
      English , otherwise.....
    Bonjour,
    Can you please upload the rom you used for your box tv ?
    Links failed.
    Thanks for sharing
      HELLO tiens j avais toujours cette box android sous rom android tv superceleron 7.1
      je l ai rallumer ce matin remis a jour my canal derniere version desinstaller l ancienne
      et hop suprise tout marche SI CA PEUT AIDER tout marche
      bien sur vous connaissez la manip
      • Ouvrez l'application myCANAL
      • Cliquez/appuyez sur votre profil en haut à droite
      • Choisissez le menu "Réglages"
      • Appuyez 4 à 5 fois consécutivement sur le N° de la version myCANAL
      • Le son "tchi tcha" va être joué puis une vidéo "Message à caractère informatif" apparaît à l'écran.
      • Faites "retour dans la section "DEBUG"
      VOILA vous forcez aussi l audio en stereo et hop mycanal remarche
      • gefattern
        gefattern commented
        Editing a comment
        can you please change it to English , English Forum
      hi,
      Thanks for sharing
      merci
        TO REPORT IN ADDITION PRIME VIDEO ALSO WORKS It is not negligible
        ( A SIGNALER EN PLUS PRIME VIDEO FONCTIONNE AUSSI C'est pas negligeable )
          Hi ,
          translate your Posts to English or i delete them , ENGLISH FORUM
