OPPO O-Fresh Earphone - Hi-Res Certification, Two Types of Interface Options
    The OPPO O-Fresh earphone has a graphene diaphragm, combined with an aluminum spool and Hi-Res audio support. The cable is braided and designed to be tangle-free, has a single button and a MEMS microphone for higher quality calls.
    Product Features:
    ● High fidelity graphene diaphragm combined with an aluminum sound coil, frequency range is 20Hz~40KHz.
    ● Hi-Res certification, restores richer music details and delivers more stereo sound.
    ● The cable is braided and designed to be tangle-free.
    ● A single button in-line remote with a MEMS microphone for clear audio calls.
    ● Equipped with three pair of soft silicone earplugs to fit different ear size, improve wear comfort and firmness.
    ● Aluminum alloy quadruple process outlines the bright green light edge, matchs with the classic color, becomes a versatile piece.
    OPPO O-Fresh is marketed in two versions, one for smartphones and devices with a 3.5mm port, another for USB Type-C, both come in two color variants: deep black and elegant gray: https://gearvita.com/oppo-o-fresh-earphone.html
    Discounted earphones:
    meizu ep52
    sabbat e12
