Sunvell Q Plus Allwinner H6 4GB 32GB 100M LAN 2.4G WIFI Android 8.1 4K H.265 VP9-10 TV Box
The tv box in this review came direct from the guys over at Sunvell who have been building TV box's for a few years now and do a good job of it.
Hi Guys,
This time we have Another Tv box to take a look at and review,The Sunvell Q Plus a Allwinner powered TV box.The Sunvell Q Plus im testing is the 4/32GB version that should be more than enough room for most users,Running Android 9.0 out the box.The box boots up at about 30 seconds so not a slow device.Theres no top and bottom bars in the UI i should mention though.I dont like not having a navagation bar so heres a work around for that from the play store.
Features:
CPU H6 Quadcore cortex-A53 frequency: 2G
GPU Mali-T720MP2
R A M: 4GB
R O M: 32GB
OS: Android 9.0
Ethernet: 100M LAN
WIFI: 2.4G
Video Decode: VP9-10 Profile-2 up to 6K@30fps, H.265 HEVC [email protected] up to 6K@30fps
(From Webpage)
The latest Android 9.0 OS ? This TV box comes with the updated Android 9.0 operating system, which is faster and more efficient. The Android box has better software compatibility, games and applications, better user interface and user experience.
4GB RAM 32GB ROM? This Android TV box offers a large amount of 4GB RAM 32GB ROM to quickly start your applications and games. You can also add an additional TF card to expand storage, which improves the reliability of your TV box and prevents failures due to lack of memory.
4K & H.265? H.265 Hardware decoding can saves 50% of bandwidth resources, you can watch movies fluently. The 4K 1080i / p resolution is 4 times more than full HD, witness scenes and characters come to life in vivid contrast, color, and clarityso you can see every detail of the screen is glossy.
Easy to use?The device supports 2.4G WIFI. Just connect the power supply, connect the DH line and WiFi or Ethernet, then you can watch the video and download the favorite APPS.
Looks and feel
It comes with just the one launcher installed.A tv box launcher (Installed nova launcher that works good)
The device itself is a square tv box with Neon light ring around the top edge,The Sunvell Q Plus has a rubber Pad on the bottom to stop it slidding around.There is NO Venterlation holes on this device.It has 2 full sized USB ports one USB3 & one USB2,Full sized SD card slot,HDMI port,Power input,AV port,RJ45 port & a Spdf port,There is a recovery button hidden behind the AV hole on the rear.The IR remote has good range & works ok (Air mouse is better).
Home Screen
App Draw
Pre installed apps
Chrome
KDPlayer (Kodi 18 beta)
Netflix
Amazon prime video
playstore
Youtube
Aptoide
Firefox
Google play store is pre installed and working fine showing apps that i like to see on a tv box
Internal photos
Top cover removed
(Unscrew 4 screws under rubber pad on bottom)
Recovery Button (Behind AV hole)
Bottom case with larg pice of metal + thermal pad
Tech Stuff
Antutu bench mark
Aida 64
DRM
Now some games testing
Beach buggy blitz (Works)
Ashpalt 8 (Works)
Sixaxis app (dont work as theres no bluetooth on this device)
Other info
Logitech c230 webcam (Works) also installed google voice search and that also works by using the webcam mic when using nova launcher.
Samsung 1TB external HD (Works)
Tronsmart Mars G01 gamepad (Works)
32GB micro SD card (Works)
Cant seem to be able to turn off the neon light on the Box
Support Decoder format:
H.264 AVC [email protected] up to 4Kx2K@30fps
H.264 MVC up to 1080P @60fps
MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496)
WMV/VC-1 SP/MP/AP up to 1080P@60fps
AVS-P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps
MPEG-2 MP/HL up to 1080P@60fps (ISO-13818)
MPEG-1 MP/HL up to 1080P@60fps (ISO-11172)
RealVideo 8/9/10 up to 1080P@60fps
WebM up to VGA
Multiple language and multiple format sub-title video support
MJPEG and JPEG unlimited pixel resolution decoding (ISO/IEC-10918)
Supports JPEG thumbnail, scaling, rotation and transition effects
Supports *.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg file HD MPEG1/2/4,H.
264, HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10
Support Media format: Avi/Rm/Rmvb/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg
Support Music format: MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE
Support Photo format: HD JPEG/BMP/GIF/PNG/TIFF
USB host: 1 High speed USB 3.0 and 1 High speed USB 2.0
Card reader: SD/SDHC/MMC cards
LAN: Ethernet:Standard 10/100M RJ-45
Firmware
What's in the box:
1 x Q PLUS android TV box
1 x Power adapter
1 x HDMI cable
1 x Remote controller(Batteries not included)
1 x User manual
Unboxing Video
