[Q] Bricked tablet?
    [Q] Bricked tablet?
    I have a Vido N101RK 10.1 inch Quad Core RK3188.
    I upgraded the firmware with the RKbatchtool.
    All went fine and it succeded.
    But now, the tablet won't startup anymore. The screen keeps black.
    And if I now connect to the Pc with USB, I get the error that the PC doesn't recognize the USB-apparatus.
    Or should I do/try a factory reset? How to do this?
    Thxs
    With RKBatchtool open, press these buttons and hold them in this order:
    Volume Down
    ESC
    Power
    Hold until the PC sees the tablet in flash mode.
    Use the upgrade instead of restore option.
    Randy
      Thanks a lot!!!
      It works.
      I was looking and looking for days, but couldn't find anything usefull on the net.
      And you could answer short and correct.
        No problem.
        I'm glad it helped!!!!!!
        Randy
          Volume Down
          ESC
          Power
          Hi! Can you help me step by step for flash this tablet.
          My rom is 4.1.1 but it is lag not smooth, if you know some roms were rooted with SU please show me. Thanks.
