Same device, other name (AC8350 BX09)?
RK3288 Devices
- Overview BOX (LINK !)
For what? Do you want to root and/or flash your device?
If you flashed your device with the Hybrid Firmware it will be rooted. Perharps you need Android Universal ADB Driver.
Yes, because I want to try to dump the stock-rom...
"Android Universal ADB Driver" dos not work at my xpsp3... (perhaps because of no entry of the "rk31sdk"??? I don't know...(perhaps because missing the "winusb.sys"???))
Somewhere here on the board I found a "K-R42 Root.ZIP" (don't ask me where) that includes USB-Drivers but my system is missing the "winusb.sys" witch is needing trough the installation (I've download it separately as single file, because I don't want to download the hole windows driver pack)
BTW: Moboro don't install something like this
- Android Phones
--- Android Composite ADB Interface
But with the above drivers it works...
NOT the ADBRK3288 Devices
[solved] ADB error: device not found
Don't ask me why and how, but now it is [solved] ADB error: device not foundRK3288 Devices
Originally posted by surr View PostI also board version 2.1 (kernel from 09.24.2013) after flashing an alternative firmware stopped working ethernet. I did not do a backup. Please Put somebody drain backup firmware. I would be very grateful.
regards
Sorry for my english
Now without reinstaling new/old firmware you have two choises. Either create wlan_mac file into /data/misc/wifi/wlan_mac directory for example from Terminal as SU enter:
Code:echo "02:03:04:05:06:EF" > /data/misc/wifi/wlan_mac
And flashing it is as easy as executing command:
Code:flash_image kernel [I]path_to_kernel_img_file[/I]
RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
LAN chip
Because I'm not allowed to edit my second post
It is a RTL8201F (I don't know with chip is on the V2.0)...
BTW:
the replacement device has no metal plate in the top cover
AND the PCB is printed with (from top to down)
CH001
1332 (instead of 1335)
TN-BX09_V2.1
2013/05/31Last edited by no_spam_for_me; 11-02-2013, 02:05.RK3288 Devices
PHYceiver LAN chip
RTL8201F isn't complete Ethernet LAN solution. It is some kind of tranceiver which "translates" signals to/from MAC layer hardware (in our case "k29 VMAC" in RK3188) communicating through 3.3V TTL standard RMI interconnect with RTL8210F to/from physical Ethernet medium. It doesn't need kernel driver per say.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Thanks for your short explanation
And thanks for MAC setting explanation in post #23
(Instead of the longer version )RK3288 Devices
also no wifi or ethernet
thanks
Originally posted by no_spam_for_me View Postthe replacement device has no metal plate in the top cover
CH001
1332 means 32th week of 2013 and 1335 equals 35th week.
My device was "borne" on 29th week of this year (between 15-19 July - only work days).RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by dynamic_d View PostHi guys I also have a android b351 and flashed lewies firmware and have no wifi or ethernet. didnt make a nandroid either. i tried advice from post 23 and no go....
Could you post output of these commands:
Code:su netcfg ifconfig dmesg | tail
Originally posted by dynamic_d View PostHi guys I also have a android b351 and flashed lewies firmware and have no wifi or ethernet. didnt make a nandroid either. i tried advice from post 23 and no go....does anybody know of a rom I can flash that just works??
thanks
This thread is about pcb TN-BX09_V2.x ...
T-R42 / CS918BT => PCB: B351_V1.0 => WLAN: AP6210 + LAN: asix ax88772
K-R42 / CS918 => PCB:CH001 TN-BX09_V2.x = > WLAN: RTL8188 + LAN: RTL8201F
I think these threads would be better for you:
T-R42/ MK888B/ CS918 with bluetooth
T-R42 custom firmware by wasserRK3288 Devices
There are currently 2239 users online. 4 members and 2235 guests.
