Main Features
● HDMI interface to connect with LCD TV, projectors and change your home TV to internet TV
● Traditional TVs connected via AV interface can also change to upgraded smart TV
● 2GB / 4GB DDR4, ( the other boxes on the market usually only 1GB ). Watch high-definition video smooth, no stuck
● 32GB / 64GB storage ( the other boxes on the market usually only 16GB ), allows for massive software download
● Google Play comes with the original screen, users can download the app themselves, such as IPTV to watch local TV channels, YouTube to watch video
● Support 4K ultra high definition output, pictures more natural and clearer
● TV box can be connected via network cable or via wireless WiFi
● LAN network port transmission speed: 1000MB/s, fast and stable
● 2.4GHz + 5.8GHz, dual WiFi antenna design, stronger WiFi signal and transfer speed
● Users can download software and save it to U disk, connect the U disk with Beelink, and then install and use the software
● U disk storage content can be played locally
● Supports voice remote control
● Supports connection with speakers, stereos, and other audio devices with BT function
● Only the size of your palm, 14% smaller than the business card, saving home space
● It has passed Google certificated, with voice remote control, support Netflix 4K
Parameters
- Android 8.1 operation system
- Amlogic S905X2 CPU, quad-core, Cortex-A53
- Quad-core ARM G31 MP2 Graphics GPU
- 2GB / 4GB DDR4 RAM + 32GB / 64GB ROM
- LAN 1000Mbps
- 2.4GHz + 5.8GHz dual band WiFi
- Support H.265 decoding
https://www.gearbest.com/446865901-_gear/
