Ship from China.
Amlogic S922X
The Beelink GT-King tv box is based on the Amlogic S922X, which is a 12nm six-core chip featuring Quad-core ARM Cortex-A73 that can reach 1.8 GHz and Dual-core ARM Cortex-A53 that can reach 1.9 GHz.
Android 9.0 OS
It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
DDR4 4GB + eMMC 64GB
The Beelink GT-King tv box is equipped with 4GB RAM+ 64GB ROM, supporting stable operations and providing you with more space and caches to enjoy your entertainment.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
Gigabit LAN
Gigabit LAN provides a data rate of 1 billion bits per second.
BUY NOW!
