[ROM] Generic Multi-Box, Multi-Wifi Custom Rom! ( Android 8.1 - S905x2 )
Just received my X96 Max, the download links does not seems to be working, kindly check please, thank you.
That's too bad, hopefully he could fix it soon, many thanks for your hard work.
Anyway, here is some hardware information of X96 Max 4+64 model for anyone interested...
Model: X96 Max 4+64G
CPU: s905x2
RAM: PS082-62BT (DDR4 4GB)
Memory: B041 (Samsung)
WLAN: AP6356SA 2.4G + 5.8G (866Mbps)
Ethernet: RTL8211 (1000Mbps)
Source: http://www.hdpfans.com/thread-820759-1-1.html
2- nop unless amlogic rls a 64bits sdk
3- i cant really say so, i dont have a ps4 remotethanks
I hope they chance to 64, because PlayStore go to 64 maybe on the future turn out to be a problem.
Later i go to tested the ps4 controler, and report
Flashed on my h96 max x2! Great rom like as my h96 pro plus device! Too bad WiFi and eth not working.
any news on when the rom will have have support for the h96 Max x2 device?
the t95x rom was working fine on my h96 max x2 device with eth and WiFi... if it helps
thanksLast edited by chenrp; 21 June 2019, 17:23.
So here is roms version:
1 RTL-BT bootanimation Multi-WiFi
1 RTL-BT bootvideo Multi-WiFi ( it uses amlogic default mbox video, look out is loud lolol )
1 BCM/AP-BT bootanimation Multi-WiFi
1 BCM/AP-BT bootvideo Multi- Wifi ( it uses amlogic default mbox video, look out is loud lolol )
Originally posted by NinthWave View Post
I am scratching my head. Can someone just explain those acronyms please. I can just get that BT stands for bluetooth but what about RTL and BCM/AP?
BCM/AP stands for a Broadcom wifi chip.
I hope it helps.
Cheers
Enviado do meu POCOPHONE F1 atrav?s do Tapatalk
I repeatedly tried the two boot animation ROMs with my A95X F2 Amlogic S905X2 Android 9.0 4GB/64GB, as well as another modded ROM at XDA (also Android 8.1). All of them stopped at 1% with the following error message:
[0x10103005]Romcode/Initialize DDR/Download buffer/Read item data failed
Could it be the different Android version? Hardware? Both?
Originally posted by jamaroney View PostI repeatedly tried the two boot animation ROMs with my A95X F2 Amlogic S905X2 Android 9.0 4GB/64GB, as well as another modded ROM at XDA (also Android 8.1). All of them stopped at 1% with the following error message:
Sometimes also some brands have their own custom uboot!
There are currently 2806 users online. 0 members and 2806 guests.
