justXBMC new firmware coming soon!
    This firmware is all about XBMC, all aditions to the firmware have lower prioryty
    If someone want to help please test how the firmware is working for you,
    share your findings and ideas, it dousnt metter its good or bad,
    as its still help
    So... let the fun begin
    My website:
    http://apkfreak.com
    v1.1.1
    xbmc internall player with dts/dolby/analog sound support
    new folder on root of sdcard:
    -justXBMC
    *plugin
    *update (update folder will be used for some minor updates to the firmware)
    -ouya mode will be now a plugin and will be not provided with the firmware
    -updated play store
    -gemail app
    -pached libmedia.so for DTS
    -new graphics
    -system bar hiden
    -rooted,boot stright to xbmc
    -better mappings for xbox wirless gamepad (supports more games)
    -init.d support
    -gameloft fix
    -new power off buackground and icons
    -nfs support with automount on startap scripts (check /system/etc/init.d folder)
    -build.prop tweaks
    -cwm recovery
    -real 1080p kernel (for compatybility with some tv res is downscaled to 720, can be changed in settings)
    -all apps deleted (only settings, es explorer, browser, download provider andcontacts are left)
    -android settings and apps can be accesed by going to programs>android apps from within xbmc
    -changed bootanimation to justXBMC
    -latest ouya xbmc with HW moded by lewy20041:
    • [*=left]advancedsettings.xml build into apk
      [*=left]playercorefactory.xml build into apk
    • [*=left]changed icons and splash screen to stock xbmc insted xbmc on ouya
      [*=left]superrepo repository
      [*=left]test skins repository
      [*=left]deleted touched skin
    OUYA mode:
    -OUYA Bootanimation
    -OUYA Keyboard
    -OUYA Launcher with working OUYA Market (OUYA Custom Launcher is made by InvaderGames from OUYA forums so all credits go to him for this )
    many ouya games are working nice with xbox360 controler.
    you will be abble to switch betwen OUYA mode and justXBMC by going to settings>advanced>swich mode
    (This mode is only for people with xbox controler, to provide plug&play gameing experience, if you dont have it do not swich modes)
    ouya mode dont harm justXBMC its just something like plugin:"
    i will provide you with stock app folder so anyone will be able to add any funcionality he/she wants by placing needed app into /system/app folder and changing permisions to
    "644" "rw- r-- r--"
    more changes will folow.
    First boot will be longer than usual as many files must be seted up
    so just go get some cofe and wait untill xbmc will start
    all boot ups after that will take much lower time but its still wont be
    super fast, its like this on purpose to make sure that sdcard
    is mounted and system is fully functional.
    OUYA Plugin
    Download:
    Whole firmware:
    K-R42
    Minix x7
    justXBMC apk for people who wont to try just the app:
    Mediafire
    Everything is possible if we work together!
    ApkFreak
    Sweet... Would this be available for an MK808, or other devices? That is the only thing I use this stick for....
      +1
        probably yes, but not so soon:"
        ApkFreak
          Very interesting!!! Can I try it on my MK908II?
            if i make it i will upload it today.
            ApkFreak
              JustWhatINEED
              Great, gonna try this baby as well. I assume it works on T428, Right?
                probably.
                but you will louse wifi and bt.
                to make it fuly funcional on t428 it need to have all modules and kernel replaced.
                i anyone will be traying to port it be sure that you are using originall boot.img and not the only system.img as its realy important.
                ApkFreak
                  I have 2 questions:
                  -Did you make any modifications in the HW Acceleration code of the XBMC to be optimized
                  For RK3188 devices ?
                  -Will the xbox wirless gamepad support be in games only or manipulating video player
                  As well ?
                    1. no but xbmc for ouya have some fixes allready and moust hd 1080p/720p play well.
                    i added external player support and hw for rockchip in advancedsettings.xml wich is activated by default now.
                    2. you can youse xbox wirless gamepad in xbmc without problem but in xbmc only dpad for navigateing.
                    ApkFreak
                      -How can you base your version on ouya while it uses a different chipset (tegra 3) ?
                      -Using the xbox360 wirless gamepad you said only dpad for navigating
                      but will i be able to control volume and seek with thumbsticks ?
                      In short the xbmc for windows has a complete mapping for xbox wirless gamepad
                      Will it be the same in your android build ?
                        ouya hardware accel use libstagefright.so thats why we can use it on rk3188/rk3066 devices.
                        as of game pad, seeking will work but volume for now no, but by editing .kl file i probably can mapp lets sey l1/r1 to volume
                        but than it will mess up some games:"
                        ApkFreak
                          Hey lewy, cant wait to try it out. am i right in assuming this will be for the mk908 first? thanks
                            I have bought my MK908 v3 to use my external hdd drive with XBMC. And i think too many user bought it for XBMC.
                            So this is great idea!
                            www.sacvideolari.com www.babatorik.com
                              I already bought an additional xbox360 game pad receiver for this as i already had 3 xbox360
                              Game pads but only one receiver.
