well another one modify was base on firmware s905w Google V2 TV. And 4.9 firmware
PoisonATV_V4.9_S905W Mod Video improvement tweak file
well another one modify was base on firmware s905w Google V2 TV. And 4.9 firmwareLast edited by antonio6o6; 18 May 2019, 04:04.Tags: None
Thank you for this edition. I notice the video quality is not that great when I use STB EMU. Not too sure if it is the server, the app, or the OS it self.
Are you able to expand on what changes you made to the software? Either way, I will try out this firmware. I believe it is the latest one for the device I have.
This OS is not that bad at all. It is much better than the stock firmware I had for my device. This OS or Custom Rom makes the Android TV a much better experience.
Originally posted by sssolider2 View PostThank you for this edition. I notice the video quality is not that great when I use STB EMU. Not too sure if it is the server, the app, or the OS it self.
Originally posted by antonio6o6 View Post
I will tell you is you IPTV provider
I have yet to install this tweaked edition but when I do, i will let you know if see any differences.
the IPTV server is a little awful because they tie you down in to using certain software or they don't give you enough freedom. I know I have alternative options , and I will use those options along with better software and better iptv server.
Originally posted by antonio6o6 View PostI will tell you I'm using that firmware Mod and the quality is great I can't complain thanks to poison team for the great work are they doing. I do got a panel IPTV service a couple of panel. I will tell you it's not the firmware Mod
I will try out this firmware mod when possible.
The IPTV server I used was from a third party where I have to use WhatsApp. My main source is greatiptvsub website.
Let me know if you can help me out with IPTV servers like which ones are the best and where I can obtain them. I prefer India , Canada, USA, UK, and VOD stuff. Sports, News, and whatever. If I can use more than one MAC IDs, that is better.
Gefattern hi the reason that I was speaking Spanish wasp that he needed help and I and I think he don't know English that's why he was speaking Spanish and I was trying to help them sorry but we need some Topic in Spanish here because I know it's a whole lot of Spanish people that they are into Android Hobby and this is great forum so I think we going to need in the future not too far to have some kind of Topic in Spanish. I'd be getting private message Spanish. Because there are no Spanish topic on this forum. And I appreciate to be here thanks
Originally posted by sssolider2 View PostI like this firmware. Everything works fine. However, Google Play Store is not working. Do you have a fresh Google Play Store APK file I can install that is compatible? Thank you for the update to this software.
I will tell you Google Play Store is working maybe you should go to setting apps go to Google Play service clear data and Google Play Store clear data
another question, how do i make android app as a favorite? for instance, i have STB emulator installed, and it shows up in favorite on the main screen. it has a yellow star. I really like that feature. any way i can add yellow stars to certain apps ? i want them to be added in favorite.
There are currently 3634 users online. 0 members and 3634 guests.
