Xiaomi MOJIETU 3S Bluetooth Music Car Charger - Good Voice Accompanies You Along The Way
    Xiaomi 3S MOJIETU car charger is a perfect integration of music player and car charger, with dual USB charger ports, shrapnel contact type electrode is adapted for all car brands in the market. Thanks to intelligent background noise reduction, clear sound quality around you. Single max output is 2.4A, and 3.4A output for dual ports, charging conversion efficiency is up to 95%.
    Product Features:
    ● Metal elastic contact design, more stable once plugged, adapted for different sizes of car cigarette lighters.
    ● Dual USB charging ports, total output can achieve 3.4A, single max output 2.4A, adapted to output 12/24 DC for global use.
    ● Smart chip automatically recognizes devices and distributes power, fully optimize the charging efficiency.
    ● Close-field FM function, perfectly transmits the audio content from App into car FM audio device by wireless projection.
    ● Connected to Roidmi APP by Bluetooth, intelligent continued play, listen to numerous high-quality internet music at any time.
    ● Empty table scanning, intelligent background noise reduction.
    ● Battery voltage detection, double synchronous reminder, more safe when driving.
    ● High-quality stainless steel, safe shrapnel-type plug electrobe technique.
    ● High standard retardant, effective avoids the danger of burning, virtual connection and heat caused by elastic meterial.
    ● High-quality brass electrobe, conductive fast, good heat dissipation, resistance to high or low temperature.
    ● Delicate and chic exterior, integrated into car interior style.
    Adopt the same production process as mobile phone, creates delicate and chic exterior. Use the grinding process on the top of surface to prevent multiple plug scratching the surface, and a mirror polishing process in the side, which can be more integrated with the surrounding environment. It is not only convenient to use, but also can be your car decoration: https://gearvita.com/xiaomi-3s-mojie...r-charger.html
    You may be interested in:
    cheap cell phones & accessories: https://gearvita.com/cell-phones-accessories
    Music Connector has a lot of content and forms many other engaging experiences.
    Free, prestigious, high-quality phone ringtones at the website: https://sonneriefrance.com/sonnerie-gratuite-samsung.
      Thanks for the clarification. get-mobdro.com
