Thanks to Gearbest we can have a look that the H6 Max
● Supports HDR 6Kimage
● 4GB RAM + 64GB ROM large memory and expandable storage
● Android 9.0 operation system
● Allwinner H6 CPU, quad core, Cortex A53
● Mali T720 GPU
● 2.4G + 5.8G WiFi + BT
● Supports H.265 decoding Specification
Brand: EACHLINK Model: H6 Max GPU: Mali-T720 System: Android 9.0 CPU: Allwinner H6 Core: Cortex A53,Quad Core RAM: 4G RAM Type: DDR3 Max. Extended Capacity: 64G |
Decoder Format: H.264 / H.265 / H.263 / HD MPEG4 Audio format: MP1/ MP2 / MP3 / WMA / OGG / AAC / M4A / FLAC / APE / AMR / RA / WAV Video format: 4K at 60fps, H.265, AVI, H.264, VC-1, MPEG-2, MPEG-4, DIVD / DIVX, Real8 / 9 / 10, RM, RMVB, PMP, FLV, MP4, M4V, VOB, WMV, 3GP, MKV Photo Format: JPEG / BMP / GIF / PNG / TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth 4.1 Power Supply: Charge Adapter Interface: 3.5mm Audio,AV,HDMI 2.0 Antenna: Yes Camera: Without Language: English,French,Germany,Italian,Spanish DVD Support: Yes HDMI Version: 2.0 Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL External Subtitle Supported: Yes HDMI Function: CEC,HDCP RJ45 Port Speed: 100Mb |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.1200 kg Package weight: 0.3800 kg Product size (L x W x H): 9.60 x 9.60 x 1.90 cm / 3.78 x 3.78 x 0.75 inches Package size (L x W x H): 17.50 x 16.50 x 4.50 cm / 6.89 x 6.5 x 1.77 inches |
Box and Bits
Remove the Base
Out with the PCB
Ports and Display, Note Using USB interface for power
GEARBEST
