Uploaded to http://www.freak-tab.de/leolas/RTL81...3_20120427.pdf
In page nº17 you can read:
"T33ramp’: The 3.3V power pre-charge ramp up duration before formal power up. It is recommended that a 3.3V power on and then power off sequence is executed by host controller before the formal power on sequence. This procedure can eliminate the host card detection issue when power ramp up duration is too long or the system warm reboot failure issue."
Seems that this chip need a pre-charge power up ramp before a formal power on, solve it is definitely out of my possibilities, so only can wait for a imito solution (I loosed all hope on it) or learn to live with this issue, the bad, we cant make wifi work in any linux distro installed in a sdcard (we have the same problem because we need to boot in recovery to boot the linux kernel).
I will sent this info to imito too, but I fear that they will not answer, like they will not answer to my other mails
