How to re-initialize LAN/eth0 ?
    My tv box (currently M8S Pro+ with LAN port, and previously M8 with USB/LAN adapter) is on the same power line with my internet router. When I enable both devices at the same time then tv box starts faster than router and this way it doesn't initialize LAN connection (WiFi works without any problem in this situation). What I tried:
    1. rebooting tv box: it helps, but it is not a preferable solution
    2. setting static IP: it doesn't help
    3. ifconfig eth0 down/up: it doesn't help
    Any ideas how can I initialize LAN ethernet in this situation?
    /B
