Beelink GT-King TV Box - SoC Amlogic S922X, Android 9.0, 2.4G Voice Remote Control
    The Beelink GT-King is one of the first Android TV box to use the new SoC Amlogic S922X - a solution that is supposed to replace the usual S905 and S912 that cross for many years. High-performance, efficient and accessible, the Amlogic S905 is one of the most popular SoCs on the TV box market. But the new SoC Amlogic S922X is a good step forward in terms of power and video quality compared to previous generations of chips.
    Main Parameters:
    CPU: Amlogic S922X, quad-core ARM Cortex-A73 and dual-core ARM Cortex-A53
    GPU: Hexa-core ARM G52 MP6 Graphics
    OS: Android 9.0
    Storage: 4GB DDR4 + 64G eMMC
    Extended Capacity: TF card up to 64GB
    Decoder Format: H.263, H.264, H.265, HD MPEG4
    WiFi: 2.4GHz + 5.8GHz
    LAN: 1000M
    Bluetooth: 4.1
    Beelink GT-King is equipped with modern WiFi antenna design that looks after amazing WiFi signal and better transfer speed. It also comes with a 2.4G voice remote control with a microphone, which is capable of taking different voice commands: https://gearvita.com/beelink-gt-king-tv-box.html
    Recommended for you:
    xiaomi amazfit deals: https://gearvita.com/xiaomi/amazfit
