Custom Recovery Without PC
Originally posted by jonv View PostIs there any way to install a custom recovery or just install a new ROM without a PC? I got my box and would like to try out some of the new ROMs. I don't have a OTG cable.
You might hold on just a minute.....
CWM isn't really intended to completely flash a NEW ROM to your device. Different custom ROM's have variations in parameters that tell the flash tool where the partitions go on the device. Because of that, you really need to flash custom ROM's from a PC. If the partitions already on your device are different sizes than the custom ROM, you could brick your device because things just can't overlap.
Manufacturers use the update.img from recovery...but they try to keep everything in standard partition sizes.
Here is an excerpt from a post I just made on one of my Pipo threads:
Code:[COLOR=#333333]CWM is really intended as a tool once you get into everyday use of your device. If things go really bad, you can use CWM to reflash the same ROM you had installed on your device.[/COLOR] [COLOR=#333333]You know how Windows has a recovery feature? You can use it to return to a stable state if you install an app that ends up jacking things up (like the wrong Rockchip drivers, hint, hint). Most people never have to use that feature of Windows.[/COLOR] [COLOR=#333333]CWM is kind of like that. The idea is to have a CWM backup on your system, so you can conveniently return to the last stable state (so it's a good idea to make a CWM backup before installing a potentially harmful app...or if you have everything perfect, the way you want it...make a backup). [/COLOR] [COLOR=#333333]Since us flashaholics have a mindset of "what to do to restore after flashing a new ROM", we look at CWM as a possible solution in that application, but it really isn't intended for that purpose. It has other features, though...like CWM app installation...and clearing cache and other cool stuff.[/COLOR] [COLOR=#333333]I keep an external SD in all of my tablets, and use Titanium Backup to keep a complete backup of apps/data. I keep the backup up to date with the current versions of each of my apps. After flashing a ROM, I immediately set up wifi, enter my Google account and go the Google Play Store to install Titanium. Then I tell Titanium that my backup is on my external SD and do a "restore missing apps with data" from Titanium, and within minutes my tablet is always back to everyday use....it takes about 10 minutes...(because the whole process is second nature to me, now).[/COLOR]
Randy
Re: Custom Recovery Without PC
Yes, is right, cwm can't resize partitions, can't flas the bootloader nor parameters and it cant erase the full nand.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
rrileypm and Leolas, not debating with you guys, but the question is: "is it possible to flash cwm or rom without a PC" the answer is YES it's possible, you can use "update.zip with a cwm zip and su zip" to install SU and install cwm, once cwm and ROOT SU installed, you can use it to flash cwm rom flashable zip like finless rom(http://www.androidfilehost.com/?fid=9390355257214632250). Of course you don't have many options like repartition etc... but just to get a custom rom (as is) with cwm and root, it's possible.
Originally posted by buhohitr View Postrrileypm and Leolas, not debating with you guys, but the question is: "is it possible to flash cwm or rom without a PC" the answer is YES it's possible, you can use "update.zip with a cwm zip and su zip" to install SU and install cwm, once cwm and ROOT SU installed, you can use it to flash cwm rom flashable zip like finless rom(http://www.androidfilehost.com/?fid=9390355257214632250). Of course you don't have many options like repartition etc... but just to get a custom rom (as is) with cwm and root, it's possible.
Root is the problem, I don't know how root the device without pc.
Originally posted by leolas View PostI know how Flash without pc cwm in rk3188 or rk3066, from terminal, and the device must be rooted, I don't know how to make a update.zip that can be flashed from the stock recovery.
leolas.
Originally posted by buhohitr View PostAh, found the missing link, yes you can install cwm and root without a PC, just copy the update.zip and cwm/su zip to the root of your sdcard, it automatically prompt to update, click yes, and it reboot your device into flash mode then it asks you which version of SU you want to use (leither superuser or superSU, I tried both and superSU is better), just pick one and it proceed to flash cwm and root files, once done it auto reboot your device back up and you need to rename/delete the update.zip from your sdcard otherwise it keeps prompt you again to update. I did this myself and worked great, I don't remember where I found the info but I do have all the files.
There are currently 1495 users online. 1 members and 1494 guests.
