TWRP Recovery 3.2.3.1 flashable for S905x2/ u211 devices
    TWRP 3.2.3.1 Recovery can be found here:
    https://forum.freaktab.com/forum/tv-...943#post758943
    (Made by Magendanz post #1518.1)
    or here: https://1drv.ms/u/s!AoqocX31ecnXgbIdSaKxLK3e-SPboA
    [HowTo] install TWRP:
    1. install "Recovery reboot app" (google playstore)
    https://play.google.com/store/apps/d...eboot&hl=en_US
    2. open app and reboot to stock recovery.
    3. in recovery choose "Apply update from EXT",
    choose sd-card and ur TWRP-u211-3.2.3.zip file.
    4. install
    5. reboot....done...
    Now reboot to twrp recovery
    (with recovery app) and do a backup first
    before u install any other firmware or rom!
    Tested on my T95Q box and it works perfect,
    so give it a try and report....
    if u wanna flash back to
    Stock recovery for S905x2 ->
    just install with twrp....
    2. open app and reboot to recovery.
    4. install
    Now reboot to twrp recovery and do a backup first
    Hi ,
    but this only works if a older TWRP is already installed , or not ???
    greetings / gefattern
      "Apply update from EXT" is an option from original recovery only, so the question is irrelevant
      tip: prefer reboot to recovery from system (any reboot app) to reach TWRP, over cold boot (toothpick method) that often end in partitions unmounted, therefore unusable. Might be an issue of it.
        Hi ,
        The twrp-zip file is signed, so it works with stock recovery of course..
          No worries, worked it out with a mouse attached
            Originally posted by csjjpm View Post
            ...how do you swipe in TWRP using the remote?
            You can't, plug in regular mouse or use air mouse remote.
