LINK FOR LICENCE.ZIP
https://www.dropbox.com/s/7wy6t2bvkwccazd/tanx%20tx5%20max%20s905x432%20ACTIVATION%20TUTORIAL.zip?dl=0 https://www.dropbox.com/s/x2tdry5uo72phhp/USB_Burning_Tool_v2.1.7.0.zip?dl=0
in zip we have:
generator.txt <-script that wil generate device ID from MAC
instruction.txt <- text tutorial
licence folder <- to recover MAC and instal device id by USB burning tool
IF YOU HAVE INSTALED ROM AND IT SHOWS YOU ACTIVATION MSG,
you have 2 options, stay with the MAC of the ROM or change to your own which you can find on the bottom of the box(sticker)
if option 1 THEN PRESS 758523 on remote control
if it will show you mac and field for activation code, you can make steps 1-3 and put device ID into field and click SET
if you try to restore mack you need to do ALL from tutorial
1.go to https://ideone.com/
2.erase all code in window and insert script from generator.txt (download and instal notepad ++ to have numered lines)
!!!!!!!!!on line 263!!!!!!!!!!!!
System.out.println(new SyncTask().sync("01:01:03:04:05:06").substring(0, 8).toLowerCase());
MIND SMAL AND BIG LETTERS, they wil generate diferent ID
--- starting run-green button ----
3. after site refresh on botom will be "stdout"... and its our DEVICE ID
( IF OPTION ONE JUST TYPE THAT ID TO ACTIVATION FIELD ON TVBOX)
4. go to licence.zip, unpack it and open deviceid.ini
[Group1] usid = 581c5d41(<--PUT YOUR CORRECT ID HERE ) [Size] Size = 8 [fragment] fragment =
on 4pda is incorrect key....usid not deviceid
5.open mac_ether.ini
[Group1] start = 90:0E:B3:02:39:AF(<-your mac) end = 90:0E:B3:02:39:FF (<-your mac with FF on last 2 place FF) current = 90:0E:B3:02:39:AF used = 0 (<-need to be 0) [fragment] fragment =
REMEMBER, LICENCE FILES NEET TO BE SAVE BEFORE LUNCHING BURNING TOOL
INSTAL BURNING TOOL
folder licence need to be in burning tool catalog
start tool USB_Burning_Tool.exe 2.1.7
file>import img>TX5MAX_key.img
then check erase flash/force erase all, erase bootloader,whether overwite key
press start and plug box holding reset button,
after succes we need to add ROM
[URL="https://chinagadgetsreviews.com/download-android-oreo-8-1-firmware-for-tanix-tx5-max-tv-box.html"]https://chinagadgetsreviews.com/down...ax-tv-box.html[/URL]
close burning tool and open it again one more time, then file> imput img>TANIX_TX5_MAX_20181226_CGR
erase flash/normal erase, erase bootloader
UNCHECK RESET AFTER SUCCESS AND UNCHECK WHETHER OVERRWRITE KEY
after success press stop unplug
Have fun
PS: ( PLEASE MOVE TOPIC TO FIRMWARE - ROMS - TOOLS)
