MXQ S805 Error to restore any firmware! Unable to mount /data /cache /system
    I've a problem with my tv box MXQ S805. I tried to upgrade firmware to Lollipop 5.1.1 with TWRP. Later installation, I had reboot of box. When the box was open, firmware doesn't worked and TWRP open again. From this moment, when i try to restore any firmware (for the S805), i get the error:
    E:Unable to mount /data
    E:Unable to mount /system
    E:Unable to mount /cache
    I've followed many tutorial, but doesn't worked. I've tried also short pin method and i get a simply reboot of system.
    I've tried also Amlogic USB burning tool, and computer doesn't recognize it with an error of USB "USB hub voltage overload..."
    Please help me. I want to restore my MXQ.
    Thanks who reply!
    I leave some photo of that i used...
    Thanks who reply!
    Hi ,
    you must flash the FW with PC , to recognize you must short Pins , you can find many Info here ,
    good luck / gefattern
      Hi ,
      Ok, thanks! So the problem is solvable? Is there a guide on how to flash from the Linux operating system?
        Hi ,
        so you only have a PC with Linux installed ??? , i take a look & report later ,
        but think well , but using big G helps too ,
        greetings / gefattern
          Hi ,
          For this week i've only a pc with Linux. But i've with me the box to search a solution for this problem. If you can help me... Thanks!
            Hi ,
            there are for sure ways to flash but i am no Linux Freak and cant help this Way ,
            you only can search here or on big G for Solution , or wait till you can get a Win
            Pc ,
            further good luck / gefattern
              Hi ,
              Pc ,
              If I try to create a dual boot (with SD) using AlexELEC, it works overpass this problem?
                UPDATE
                I've flashed FW with "Amlogic USB Burning Tool" and i've fix this problem.
                PC didn't recognized box because USB cable it was damaged.
                I succeeded to create dual-boot with Android 4.4.2 / AlexElec (or LibreElec, CoreElec etc.)
                Thanks for your helps!
                  UPDATE
                  Hi ,
                  nice to hear ,
