(ROM) Minixfreak_OS S905W May25/2019 ""NEW""
    Minixfreak OS Changelog
    Bases:
    -S905W Based off TX3 Mini L firmware
    -S905X Based off TX7 firmware
    -S912 Based off Z6 firmware
    -S912 LPDDR Based TX92 firmware
    Features:
    -AndroidTV OS
    -TWRP installed
    -Optimized Bluetooth and Wifi Drivers
    -Voice Search Added
    -Picture In Picture Added
    -Google Assistant Added
    -External Broadcom Bluetooth Added
    -GamePad Support Added (PS,Xbox etc)
    -Init.d Tweaked to the max
    -Build.prop Tweaks
    -Amazing Themed Icons and wallpapers
    -S912 opengl 3.2 Support Added
    -Amcodec Added
    Fixes:
    -Wifi disconnect fixed
    -Codecs fixed and optimized
    -Various crashes when using certain apps
    -Wifi not detecting mostly Fixed
    Tips&Info
    - Faster boot time
    -Extremely tested tweaks(Some Interfeared with each other) Works amazing now
    -Added Airscreen app (Chromecast alternative)
    -Added ES File Explorer Pro
    -Added STBEMU Pro
    -Added Darkmedia IPTV APP (Works amazing Only English tho) Please sign up for it on https://darkmedia.tv/ Truly Amazing Iptv, Also It updates through playstore automatically when update is available
    -I Put a lot of time into the firmware and hope everyone likes it ?, I cant please everyone with every single device out there? some devices are different and ppl have to face that ? its mostly universal firmware but not completely.
    Thanks Everyone who supported me
    I try not to accept donations with cash itself but people actually sending me the box to develop for , Rockchip and S905X2 will come soon ? Stay Tuned
    Downloads:
    https://mega.nz/#F!5o5B0SII!p-W0crI8UbegQNA80vKSzQ
    Thanks. This firmware works in new Tanix tx3 mini-A model.
      Yes
        When i start TWRP don't detect system, data, etc... And i can't mount It. I need It for install clock display patch of Tanix tx3 mini-A and i can't.
        Any solution?
          Any solution?
          Where I did I put it on the download folder the clock display patch and it download and I got the clock with no problem on my tx3 minix
            Sorry, buy i don't understand. Can you tell me what did you do exactly in castellano in a private message? Thanks.
              Okay what I did was open File Explorer I put the patch clack on download folder then I went back to setting about system upgrade. And from there I think you know what to do
                Bases:
                Features:
                -AndroidTV OS
                -TWRP installed
                -Voice Search Added
                -Build.prop Tweaks
                -Amcodec Added
                Fixes:
                Tips&Info
                - Faster boot time
                -Added STBEMU Pro
                Downloads:
                Please can this firmware restore my tanix tx3 mini back to life Thanks
                  yes
                    Thanks for the great firmware!
                    I have 2 similar tvboxes running it, and noticed they both have the same ethernet mac. Is the mac stored in the firmware? If so, can I alter it somehow?
                      Hi there is also the 1gb version for s905w please? thanks a lot
