MXQ-4K slowest, please help!
    hi my friends, i have a MXQ-4K and the tv box has android 7.1.2 and with this hardware:
    CPU: QUAD Core -Cortex RK3188 of 4 Cores to 1.4Ghz
    Memory: 8GB
    Memory RAM: 1GB - DDR3
    Wifi: SV6051P wifi chip
    Motherboard: R329Q_V3.2 manufacturing date:2018-08-14
    Im looking for ROM or Fimware, because i need update or tweak my tv box, is slowest for open any app and when i open kodi or others tv media players, it takes to change the channel up to 5 minutes, please help!.
    thanks for the answer
    Memory: 8GB
    Hi ,
    first , is your Box a RK3188 or RK3229 Box , think RK3229 , there are for sure some Roms to find
    for your Box , you only have to search here in RK3229 or under Firmware/Roms/Tools ,
    further good luck / gefattern
      if you are root user intall some application to delete files of factory example:
      *bluettoth
      *calculator
      *voice options (mxq does not have a microphone)
      *camera
      *gmail
      *etc
      optional:
      delete the play store
      and disable google play services aprox 140mb (more of ram)
      disconect the box conect and press button reset 10 seconds use the remote control go to factory reset and wipe restart
      and intall all apps saved in you sd
      go settings and press 7 times compilation number
      developer mode
      go to
      scale animation 0.5x (all 3)
      second plane prosees max 2
      force gpu
      force cpu
      max proseees second plane 2
      srgb (optional)
      for last intall
      the app
      ram boster expreme pro
      settings:
      supper extreme
      boot frecuency 1 min
      boots at device start up
      buy one fan cpu and intall it in the port usb for keep cold
      remember your device only has 1 gb of ram for android 7.1,
      EXAMPLE have cell phone j5 prime with android 7.1 and consumed a lot of ram almost 1,3 gb, from
      factory updated to android 8 and optimizing everything I have 900 mb of ram free of 2 gb.
      In CONCLUSION, andropid 7.1 this badly damaged consumes more than it needs.
      I recommend not updating firmware for any reason many clones of mq pro 4k no matter how much you paid for it.
      With my recommendations you can run your Android fluid without any problem avoid updating.
      INTALL FIRMWARE IS THE LAST OPTION There are many ways to fail.
