Pipo M6 problems charging.
Does this sound familiar, and if yes, what can be done about it: My Pipo M6 will charge, but not always. When i try to charge my M6, sometimes it charges, but most of the time it won't charge. I put the charger in my M6 and have to fiddle around with the connector in the connection on my M6. Then sometimes it charges for some minutes, and then it stops charging again. So now it takes me some 16-17 hours to charge my M6 as every few minutes i need to fiddle the connector, twisting it around, and then it charges again for a minute or so, and i have to do the same twiddling, fiddling.Anyone recognises this, and what can be done about it?Tags: None
Is this the original charger, or a newly bought replacement? I thought I lost mine and purchased a Chinese replacement and it wouldn't charge, doing things similar to what you claim. I eventually found my original charger and it worked all fine again.
PiPo M6 Max 3G RileyROM 1.9
Hyundai T7s SPCleanROM 4.04
Asus Transformer Prime ChaOS 4.3.1
Samsung SGSII SlimBean 4.3 Build 2.2
Originally posted by Piet View PostDoes this sound familiar, and if yes, what can be done about it: My Pipo M6 will charge, but not always. When i try to charge my M6, sometimes it charges, but most of the time it won't charge. I put the charger in my M6 and have to fiddle around with the connector in the connection on my M6. Then sometimes it charges for some minutes, and then it stops charging again. So now it takes me some 16-17 hours to charge my M6 as every few minutes i need to fiddle the connector, twisting it around, and then it charges again for a minute or so, and i have to do the same twiddling, fiddling.Anyone recognises this, and what can be done about it?
There are currently 2392 users online. 0 members and 2392 guests.
