After a couple of factory resets the same thing happened every time.
After talking with customer service they recommend to update to newer firmware. The one from their link didn't work.
I tried with Nano Nexus from Magendanz with OTA version and it worked, but i didn't really like it.
After i got the cable i tried with USB burning tool, and tried a couple of different ROM(poison v2, stock and nano from Magendanz, stock from mecool) and non of them worked.
With stock it got to 49% and stopped.
I use Burning tool v2.1.6.
I think there is a problem with memory on the device, and that is why it doesn't work. Maybe i am doing something wrong? In the link i saved a couple of log if it means anything to anybody.
