Help for custom rom tools
    Hello,
    I hope to be in the good section of the forum.
    I'm trying to create a custom rom for my TV box with Android 8.1.
    I managed to modify the system.img to modify the bootanimation.
    Now I do not know what to do to flash the change on the system.img repack.
    I would also like to customize the APK installation and configuration of the language + keyboard how to do?
    Thank you in advance for your help
    Hello and welcome,
    First you can modify a Rockchip system.img easy in Linux.
    Just mount it modify and unmount there is only one bottleneck the size.
    But you can change the size also easy.
    For reflash to your device easy way is to use Android tools for Rockchip and burn it.
    This are the link for driver and tool.
    ​​​​​​​Neomode
      Hello neomode
      I'm using RKDevTool to try to write the system.img file in the system partion of the box but I have an error. Click image for larger version
ID:	774507 Do you have an idea ? Then how to package a firmware file containing all the IMG files of the box (boot, kernel, oem, recovery, resource, security, system, uboot, vendor, etc ...) It will be easier to flash all partitions with AndroidTool. Thank you
        Yes I have a Idea.
        You must write the hole ROM back to the Device not only the system.img.
        Hope you have the full Rom.
        Neomode
          Even specfying all images it does not work ...
          Is there another software for flashing?
            Take the Rockchip Android Tool for Flashing I linked it above for you.
            Also check the Size of your System.img.
            In some cases you can?t Customize the Rom cause they have an Protection in it.
            Take Android Tool and make Erase Flash then you are in Mask Rom Mode.
            Then Flash again, sometimes this Helps.
            Neomode
              OK, Where can I find the loader and the parameter.txt file ??
              How do we know that the system image is protected ??
              You must use the lowerformat button in the Download Image menu ??
