Hi there if I could get some help with identifying my this device I would be greatly appreciative.
I took pictures of the board for you to examine and if your able to let me know how you come to your conclusion to save me some time in the future that would be excellent.
I believe its a GT1 but after opening it up and reading the board it says GT-L or GT - V20 from 2016,
I use the device to test custom Rom with and I would normally s912.img and the only issue I come across is when I connect Bluetooth headset the audio is garbled.
So I guess your Box is like a Probox2 Air+.
I think that the ROM for that Box should work on your Device.
Also the Beelink Firmware should work fine too.
