MX10 Pro 6K TV Box Maximizes Your Living Room
    Are you still buying 1GB boxes in 2018? As we all know, the larger the memory, the smoother the use. Today's mobile phones are basically equipped with 3 - 4GB memory, this shows that the memory is the basic guarantee of product flow. MX10 Pro 6K TV box 64GB adopts 4GB DDR3 memory, load faster and run faster, makes sure you watch TV and play games smoothly. It fully supporting Preminum 6K UHD contents with a powerful 64bit CPU and Mail T720 GPU combination in place to handle 6K graphics and offers strikingly realistic pictures.
    Main Parameters:
    CPU: Allwinner H6 Quad Core 64-bit ARM Cortex-A53
    GPU: High-performance multi-core GPU Mali T720
    OS: Android 9.0
    4GB DDR3 + 64GB EMMC
    Storage Extension: microSD(TF) up to 128GB
    WiFi: IEEE 802.11a/b/g/n, 2.4G
    Ethernet: 100M LAN
    Video decode: VP9-10 Profile-2 up to 6K@30fps, H.265 HEVC MP-10 @L5.1 up to 6K@30fps
    The box supports 6K resolution, gives you much better definition than 4K box, much more colorful life: https://gearvita.com/mx10-pro-6k-tv-box-4gb-64gb.html
    Another version:
    MX10 Pro 6K TV box 32GB: https://gearvita.com/mx10-pro-6k-tv-box-4gb-32gb.html
