Keyboard case for pmid701c
Hope it works for you
I'm not sure it will though, because if you look at the mount points on the side of the device, and the teeth on the case itself, it doesn't look like it will match up exactly, unless of course is snaps onto the face of the device. Be sure to let us know if it works out for you though.
I took the plunge X5
I ordered 5 of these (3 black and 2 pink) for my family. Four of us have the Polaroid PMID700 and the other has the COBY 7". The only difference is I found a distributer in New Jersey with the same thing for rougly the same price. http://www.****.com/itm/120809330701...84.m1423.l2649 I figured I'll get it quicker that way. I'll let you know how well they work for both tablets.
Originally posted by Jack Rabbit View PostI ordered 5 of these (3 black and 2 pink) for my family. Four of us have the Polaroid PMID700 and the other has the COBY 7". The only difference is I found a distributer in New Jersey with the same thing for rougly the same price. http://www.****.com/itm/120809330701...84.m1423.l2649 I figured I'll get it quicker that way. I'll let you know how well they work for both tablets.
Originally posted by Bruiserman View PostJim
Ainol Novo 7 Elf II Dual Core
Milestone (Droid) - Chevy SS GB ROM
Milestone X - Rooted Stock GB ROM
Originally posted by Bruiserman View PostJust got mine, plugged it in and nothing. Not sure how to set it up. It's the same as in the link I posted at the beginning.Jim
Originally posted by Lexridge View PostDid you get the extra cables with it? Mine came with two. If so, try it with a standard USB keyboard. Mine also works fine with that.
Originally posted by Bruiserman View PostMine has the same plug as the one that charges the tablet. I only got the main cord and no others. Wonder if I need some kind of adapter. Was hoping it would plug and play. When I plug it in I don't get any power to the keyboard.
The mini keyboard has its own cable, which I connected directly to my 701i, plus it came with two OTG cables. One which I used to connect the Dell keyboard. I did this both direct, and with a 4 port hub, and it worked both ways.
I didnt have to do anything special. All three keyboards lights on the mini flashed as soon as it was plugged in, and it worked.Jim
There are currently 2357 users online. 0 members and 2357 guests.
