8GB+256GB / 8GB+512GB for your reference.
Intel Core i3-5005U
The Intel Core i3-5005U is a ULV (ultra low voltage) dual-core processor based on the Broadwell architecture. In addition to two CPU cores with Hyper-Threading clocked at 2.0 GHz (no Turbo), the chip also integrates an HD Graphics 5500 GPU and a dual-channel DDR3(L)-1600 memory controller.
Pre-installed Windows 10
Beelink L55 Mini PC is pre-installed with Windows 10 home so that our users are able to enjoy the advanced functions of Windows OS directly.
Dual Band WiFi
With support for 2.4GHz and 5.8GHz band, it can transmit higher amounts of data, and it's naturally less congested.
Gigabit LAN
Gigabit LAN can improve the net speed and the performance to a large extent.
BUY NOW.
