Intel Broadwell I3-5005U Intel HD Graphics 5500 Expandable 2TB 2.5 inch HDD 1TB SSD 2.4GHz + 5.8GHz WiFi 1000Mbps Dual Gigabit LAN USB3.0
Brand: Beelink Model: L55 Type: Mini PC System: Windows 10 CPU: Core-i3-5005U Core: Dual Core GPU: Intel HD Graphic 5500 RAM: 8GB RAM Type: DDR3L Maximum External Hard Drives Capacity: 2TB Color: Black |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: 4K,AVI,DAT,ISO,MKV,MP4,MPEG,MPEG-1,MPEG-4,MPEG1,MPEG2,MPEG4,RM,WMV Audio format: AAC,APE,FLAC,MP3,RM,WMA Photo Format: GIF,JPEG,JPG,PNG Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes WIFI: 802.11 a/b/g/n/ac, Dual-band WiFi 2.4GHz/5GHz , Dual wireless antenna Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: 3.5mm Audio,DC Power Port,DP,HDMI,LAN,Mic,USB2.0,USB3.0 DVD Support: No HDMI Version: 1.4 Other Functions: ISO Files,Others HDMI Function: HDCP Power Consumption.: 10W RJ45 Port Speed: 1000Mbps |
System Bit: 64Bit WiFi Chip: Intel 3165 System Activation: Yes |
Power Type: External Power Adapter Mode Power Adapter Input: 100-240V / 50-60Hz |
Product weight: 0.2790 kg Package weight: 0.7980 kg Product size (L x W x H): 12.80 x 12.60 x 4.60 cm / 5.04 x 4.96 x 1.81 inches Package size (L x W x H): 16.00 x 16.00 x 7.50 cm / 6.3 x 6.3 x 2.95 inches |
Package Contents: 1 x Mini PC, 1 x Power Adapter, 2 x HDMI Cable, 1 x Bracket, 1 x Pack of Hard Disk Screws, 1 x English Manual, 1 x English After Sales Card |
