Sunvell Q Plus TV Box - 6K UHD, Allwinner H6
    Sunvell Q Plus adopts Allwinner H6 quad-core high-end master chip, which is Cortex A53 architecture. The chip provides a powerful processing capacity and has a great ability to decode. The TV box is based on the Android 8.1 OS, with high speed and smooth performance, turns your regular TV into a smart one.
    Main Parameters:
    CPU: AllWinner H6 Quad-core ARM Cortex A53
    GPU: Mali-T720MP2
    OS: Android 8.1
    Storage: 4GB RAM + 32GB ROM
    Ethernet: 100M LAN
    WiFi: 2.4G
    Video Decode: VP9-10 Profile-2 up to 6K@30fps, H.265 HEVC [email protected] up to 6K@30fps
    Q Plus supports 6K output, provides much better resolution than 4K TV box: https://gearvita.com/sunvell-q-plus-...-4gb-32gb.html
    Another specification:
    Sunvell Q Plus 64GB: https://gearvita.com/sunvell-q-plus-...-4gb-64gb.html
