Zidoo 2.1.24 firmware for LAKE I, BEELINK SEA I, PROBOX2 AVA.
    Minimum changes compared to the original Zidoo firmware.
    Anything that works on zidoo will most likely work here, including zdmc.
    The control of the screen on the zidoo front panel is blocked (we still do not have it). Instead, the settings are added to adjust the brightness of the clock LAKE.
    The special buttons of the native LAKE remote control (browser, media, settings) will not work.
    Add-on that includes the Android TV interface for Zidoo 2.1.24 firmware
    It works only on firmware Zidoo X9S 2.1.24.
    During installation, the settings and installed programs will be saved.
    Rollback only through repeated firmware zidoo 2.1.24, so make a backup of your settings.
    Installation
    1. Install zidoo_ota https://my-files.ru/0hk3f9
    2.Run the system update and select "USB Update". Specify the path to the downloaded file (no need to unpack the file).
    3.The update will be installed and the console will reboot.
    Links are down.
    I really need this firmware.
    Also, I hope you make the instructions a bit clear.
    Thank you
      Pls help!!! I use fw zidoo 2.1.24 for lake i, today i have news message from zidoo it have new fw 2.1.28. I download it from offical zidoo x9s page and dump fw by usb but unfinish it can' update anything. And it freeze this page. I try to reboot but it not happenning. Pls tell me and let me know how reslove this problem? Regarding Every member.
        You will need to use realtek flash utility to reflash the firmware by computer. You need a USB male to male cable.
        Do you have this ROM? can you please upload it?
          I try to use "rtumdfsample" to reflash firmware by usb male to male ready but it have a problem by this message. It can't not reflash the firmware. Pls sugges for me.Click image for larger version
          Do you have this ROM? can you please upload it? =>> https://www.mediafire.com/file/6jmft...oNews.zip/file
            Flash original Lake or Beelink SEA firmware first
              I try to reflash fw Lake I by our topic from freaktab but it same as problem. I dont't know what happening. It show same mesaage error.
                try probox2 ava fw
                  try probox2 ava fw
                  I try same as possible.Click image for larger version
                    Change flash type to EMMC. And if you have another (Short) cable you can try it. You can also change your computer and see
                      Thank you very much for help me too. Tomorrow I just report to you again. Regards,
                        Now...Every thing successfully. My Lake I can be use already. it have problem with my step on rtumdfsample. Thank you for your help until now. Regarding
                          This FW is garbage, Google play will not even show you apps like Hulu, Netflix, Pluto TV etc etc
                            Can I use zidoo remote control directly?
                              It's possible to make a version for X5 xnano?
                              I will donate Happy best regards...
