2GB+32GB / 4GB+64GB for your reference.
Intel Atom X5-Z8350
Z83V MINI PC is powered by the quad-core 64-bit Intel Atom X5-Z8350 processor at 1.44Ghz with a turbo frequency of 1.92Ghz. The CPU features the latest 14nm manufacturing process and Gen8 Intel HD Graphics.
Pre-installed Windows 10
Z83V MINI PC is pre-installed with licensed Windows 10 home so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn K8 into a work assistant as well as a life-partner. With Windows 10 OS, you can sync game display to any device of Windows 10 OS. What an amazing scenario! When your friends are watching football matches on TV, you can play games on Xbox and display on another PC screen.
Dual Band WIFI
With support for 2.4Ghz and 5.8Ghz band, it can transmit higher amounts of data, and it's naturally less congested.
1000M LAN
BUY Beelink Z83II Windows 10 64Bit Intel Atom X5 Z8350 4K MINI PC NOW.
