4GB+64GB / 4GB+128GB for your reference.
Amlogic S905X2
MECOOL KM3 tv box runs Android 9.0 on Amlogic S905X2, which provides the user with ultra-fast running speed and professional image processing.
Android TV 9.0 OS
It is based on the Android TV 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
DDR4 4GB+ eMMC 128GB
MECOOL KM3 tv box is equipped with 4GB RAM+ 128GB ROM, supporting stable operations and providing you with more space and caches to enjoy your entertainment.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
100M LAN
Equipped with 100M LAN Interface for unfettered internet surfing.
BUY Mecool KM3 NOW.
