New Firmware Beelink GT-King 2019-06-14-1907
The weight of the file to download was about 565Mb, my Beelink GT King has been updated without problems in less than 2 min, without looking much and after the first reboot of the device so I can see it seems that they have not yet solved the problem of the network connection between RJ45 and Wifi. My device also had this problem both with the original firmware of 2016-05-08 and with the updated 2016-05-27, the icon corresponding to the connection by cable marks me that I am connected at the same time as in settings it puts me "ethernet connection established" but there really is no internet connection and I'm pretty sure it's nothing from my network hardware since another tv-box that I have R-Tv S10 (amlogic S912, android 7.1) works perfectly, I think it's a problem of an unpolished A9 software.Last edited by Bunzo; 17 June 2019, 13:30.
Hi there & welcome to freaktab.
The best and safest way to flash any TV Box is to use an Image and the USB Burning tool2.1.7.0
But if you really want to do it with a SD card
Here is a SD card version dated 20190509 I cant find a SD version any newer.You could use that and then update via OTA to the latest FW
BlinkyPlease consider making a Donation to freakTab
There are currently 1762 users online. 1 members and 1761 guests.
