Support Netflix 4K / Amlogic S912 / 3GB RAM / 32GB ROM / 2.4G 5G WiFi / 1000Mbps / HDMI 2.0 / VP9 / H.265 / Supports HDR10
Descriptions:
The Beelink GT1 - A Ultimate featuring the latest processor. It is equipped with the Amlogic S912 CPU which enables you to have a smooth entertainment experience. It also has a 3D noise reduction filter. Change your visual enjoyment. No need to go to the cinema to watch 3D movie, TV box supports 4K video. You won't miss a single detail at home. This box comes with Android 7.1 system which is faster and more efficient.
Main Features:
?Amlogic S912 CPU with octa-core is rapid and stable, it can give you high-speed feedback and smooth response
? It has passed Google certificated, with voice remote control, support Netflix 4K
? Dual Band WiFi: 2.4G plus 5.8G can improve the speed which can implement multitask
? 1000Mpbs LAN can improve the net speed and the performance to a large extent
? H.265 and VP9 - 10 Profile - 2 decoding will offer you high definition pictures and movies
? It owns the 3D noise reduction filter which is convenient for you to enjoy the high-quality entertainment
? The remote control power: 2 x AAA batteries ( not included )
