Product Features:
● Bluetooth 5.0 & Qualcomm QCC3003 chipset, reduces data transmission and power consumption significantly, improves connection stability and compatibility.
● Ergonomical design, 33g ultra-light body, comfortable to wear.
● Light and flexible neckband, made of skin-friendly silicone material, with a streamlined design, fits perfectly to the neck.
● 140mAh battery, 12 hours playing time, 300 hours standby time and 1.5 hours charging time.
● Composite diaphragm with 10mm large dynamic coils to deliver real sound.
● CVC 6.0 broadband noise reduction, eliminates most of the low-frequency noise.
● MEMS silicone microphone with excellent stability in anti-noise performance, makes clearer calls.
● Magnetic earphone shell, eliminate cumbersome storage steps.
The UMIDIGI Ubeats will get the bottom price of $21.99, act fast if you are interested: https://gearvita.com/umidigi-ubeats-earphone.html
You may also want to:
purchase sabbat e12
purchase qcy t1s
