MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16
Works pretty much as it should
Specification
Brand: MECOOL Model: KM9 Pro Classic Type: TV Box GPU: Mali-G31 System: Android 9.0 CPU: Amlogic S905X2 Core: Quad Core RAM: 2G RAM RAM Type: DDR3 ROM: 16G ROM Max. Extended Capacity: TF card up to 64GB (not included) |
Decoder Format: H.263, H.264, H.265, HD MPEG4 Audio format: AAC, FLAC, MP3, OGG, RM, WMA Video format: AVI, DAT, ISO, MKV, MP4, MPEG, RM, WMV Photo Format: BMP, GIF, JPEG, JPG, PNG, TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: No Bluetooth: Bluetooth 4.0 Power Supply: Charge Adaptor Interface: AV,DC 5V,HDMI 2.0,LAN, TF card USB2.0 and USB3.0 Language: Multi language HDMI Version: 2.0 Other Functions: Others |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.1100 kg Package weight: 0.4000 kg Product size (L x W x H): 10.00 x 9.80 x 1.95 cm / 3.94 x 3.86 x 0.77 inches Package size (L x W x H): 19.50 x 13.00 x 6.50 cm / 7.68 x 5.12 x 2.56 inches |
Package Contents: 1 x TV Box, 1 x Power Adaptor, 1 x Voice Remote Control, 1 x HDMI Cable, 1 x English User Manual |
The Box
What's in The BOX
Remove the lid
Remove the PCB
Top View
Ports
Remote
Gearbest > MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16 <
Don't forget 39.99 with GBCNKM9C01 coupon at Gearbest
For Discussion on the MECOOL KM9:
https://forum.freaktab.com/forum/tv-...id-tv-box-2-16
