Main Features
● Android 9.0 operation system
● RK3229 CPU, Quad core, ARM Cortex-A7, up to 1.5GHz
● Mali-400 MP2 GPU
● 1 / 2GB DDR3 RAM + 8GB / 16GB ROM
● 2.4GHz + 5GHz dual band WiFi
● 100Mbps Ethernet
● Support 4K ultra HD image display
● Support H.265 decoding
● IR Infrared voice remote control
